Acceleration Units Converter
Converting between units of acceleration.
acceleration
Acceleration is the ratio change of velocity to change in time - and can be expressed as
a = dv / dt                          (1)
a = acceleration (m/s2, ft/s2)
dv = v1 - v0 = change in velocity (m/s, ft/s)
dt = t1 - t0 = time taken to change the velocity (s)
Online Units Acceleration Calculator
The calculator below can be used to convert between some common acceleration units:
Acceleration vs. change in time and velocity
Download and print Acceleration vs. Change in Velocity and Time chart
Example - Acceleration of a Car
A car accelerates from 0 km/h(0 m/s) to 100 km/h(27.8 m/s) in 5 seconds. The acceleration can be calculated by using km/h as the units for velocity:
a = ((100 km/h) - (0 km/h)) (1000 m/km) (1/3600 h/s) / (5 s)
   = 5.6 m/s2
The calculation can be simplified by using m/s as the units for velocity:
a = ((27.8 m/s) - (0 km/h)) / (5 s)
   = 5.6 m/s2
  • Basics
  • Dynamics
  • Mechanics
  • The Engineering ToolBox (2008). Acceleration Units Converter. [online] Available at: https://www.engineeringtoolbox.com/acceleration-converter-d_1284.html [Accessed Day Month Year].
