Bimetallic Strips
Heat and bending of bimetallic strips.
Bi-metallic strips are subject to bending due to heat - and can be used to convert change in temperature to mechanical displacement.
Bending occurs towards the side of the metal with the lowest temperature coefficient of expansion.
Bimetallic strips - temperature bending
Bi-metal strips
  • consists of two strips of different metals with different temperature expansion coefficients
  • are usually made with steel (12 x 10-6 K-1) and copper (16.6 x 10-6 K-1) (or brass 18.7 x 10-6 K-1) joined together (often welded) throughout the length
  • are typically used in thermostats
Assuming two metals with the same shape joined together - bending of a bi-metal strip due to change in the temperature can be calculated as
s = α L2 dt / t                                 (1)
s = bending (m)
α = 13-19 x 10-6 K-1 (typical aprox. 14 x 10-6 K-1 - check manufacturers catalogs and specifications)
L = length of bimetallic strip (m)
dt = temperature difference (oC)
t = thickness of bimetallic strip (m)
Example - Bending of Bi-metal strip
A bi-metal strip with α = 14 x 10-6 K-1, length 50 mm and thickness 2 mm is heated 100 oC. The bending can be calculated as
s = (14 x 10-6 K-1) ((50 mm) 1/1000 m/mm)2 (100 oC) / ((2 mm) (1/1000 m/mm))
  = 0.00175 m
  = 1.75 mm
  • The Engineering ToolBox (2011). Bimetallic Strips. [online] Available at: https://www.engineeringtoolbox.com/bimetallic-strips-d_1755.html [Accessed Day Month Year].
