Boiler Blowdown Rate
Calculate boiler blowdown rate.
A blowdown of the boiler is a routine operation necessary due to the increased concentration of Total Dissolved Solids - TDS - in the boiler water when producing steam.
The blow down rate of a boiler depends on
  • steam consumption (steam used in the process and not returned as condensate to the boiler)
  • concentration of impurities in the feed water
  • maximum allowable TDS in the boiler
The blowdown rate can be calculated as
qBD= qS fc / (bc - fc)                                        (1)
qBD = blowdown rate (kg/h)
qS = steam consumption (kg/h)
fc = Total Dissolved Solids - TDS - in the feed water (ppm)
bc = maximum allowable Total Dissolved Solids - TDS - in the boiler water (ppm)
  • Steam and Condensate
  • The Engineering ToolBox (2008). Boiler Blowdown Rate. [online] Available at: https://www.engineeringtoolbox.com/blow-down-rate-d_1063.html [Accessed Day Month Year].
