Mineral Wool Insulation
Mineral wool is made from molten glass, stone or slag that is spun into a fiber-like structure. Inorganic rock or slag are the main components (typically 98%) of stone wool. The remaining 2% organic content is generally a thermosetting resin binder (an adhesive) and a little oil.
Mineral wool thermal conductivity vs. temperature are indicated in the charts below:
Mineral wool - Thermal Conductivity - Metric Units
Mineral wool - Thermal Conductivity - Imperial  Units
  • T(oC) = 5/9[T(oF) - 32]
  • Insulation
  • The Engineering ToolBox (2007). Mineral Wool Insulation. [online] Available at: https://www.engineeringtoolbox.com/mineral-wool-insulation-k-values-d_815.html [Accessed Day Month Year].
