NEMA A, B, C and D Electrical Motor Design
NEMA has established the four different designs A, B, C and D for electrical induction motors.
Different motors with the same nominal horsepower may have different start current, torque curves, speeds and other variables. When selection a particular motor for an intended task all engineering parameters must be taken into account.
The four NEMA (National Electrical Manufacturers Association) designs have unique speed-torque-slip relationships - making them suited for different type of applications.
NEMA design A
  • maximum 5% slip
  • high to medium starting current
  • normal locked rotor torque
  • normal breakdown torque
  • suited for a broad variety of applications - like fans and pumps
NEMA design B
  • maximum 5% slip
  • low starting current
  • high locked rotor torque
  • suited for a broad variety of applications with normal starting torques - common in HVAC application with fans, blowers and pumps
NEMA design C
  • maximum 5% slip
  • suited for equipment with high inertia and high starting torques at start  - like positive displacement pumps, conveyors
NEMA design D
  • maximum 5-13% slip
  • very high locked rotor torque
  • suited for equipment with very high inertia starts - like cranes, hoists etc.
  • Electrical
  • The Engineering ToolBox (2004). NEMA A, B, C and D Electrical Motor Design. [online] Available at: https://www.engineeringtoolbox.com/nema-a-b-c-d-design-d_650.html [Accessed Day Month Year].
