Projectile Range
Calculate the range of a projectile - a motion in two dimensions.
Projectile - flight and range
The time for a projectile - a bullet, a ball or a stone or something similar - thrown out with an angle Θ to the horizontal plane - to reach the maximum height can be calculated as
t h = v i sin(Θ) / a g (1)
t h = time to reach maximum height (s)
v i = initial velocity of the projectile (m/s, ft/s)
Θ = the initial angle of the velocity vector to the horizontal plane (degrees)
a g = acceleration of gravity (9.81 m/s2, 32.174 ft/s2)
The total flight time can be expressed as
t s = 2 t h
= 2 v i sin(Θ) / a g (2)
t s = time for the total flight (s)
The maximum elevation - h - of the flight can be calculated  as
h = 1/2 a g t h 2 (3)
h = flight maximum elevation (m, ft)
The horizontal distance of the flight can be expressed as
s = v i 2sin(2 Θ ) / a g (4)
s = flight distance (m, ft)
Example - Throwing a Ball
A ball is thrown with initial velocity 25 m/s in angle 30 degrees to the horizontal plane. The time for the ball to reach maximum level is
t h = ( 25 m/s ) sin(30 degrees) / ( 9.81 m/s2)
= 1.27 s
The maximum elevation of the ball can be calculated as
h = 1/2 ( 9.81 m/s2) ( 1.27 s < )2
= 7.91 m
The horizontal distance traveled by the ball can be calculated as
s = ( 25 m/s )2sin(2 30 degrees ) / ( 9.81 m/s2)
= 55.2 m
Projectile Flight Calculator
The calculator below can be used to estimate the time of flight, time to reach maximum elevation, maximum elevation and flight distance for a projectile like a bullet or a ball or something similar.
Note that friction force due to air resistance is neglected.
Projectile - velocity, elevation and maximum distance
Projectile - velocity, elevation and maximum height
Note that friction force due to air resistance is neglected in the charts above. For higher velocities range and maximum height will be dramatically reduced.
  • Dynamics
  • Mechanics
  • The Engineering ToolBox (2014). Projectile Range. [online] Available at: https://www.engineeringtoolbox.com/range-projectile-d_1908.html [Accessed Day Month Year].
