Thermodynamics
Using steam to humidify air.
Air and Steam Mixtures
Air in the steam will lower the surface temperatures in heat exchangers - and less heat will be transferred.
Boiler Capacities
Steam boilers output can be expressed in Boiler Horsepower, MBTU or in Pounds of Steam delivered per hour.
Boiler Horsepower
Boiler horsepower vs. heat transfer area.
Boiler Water - Total Dissolved Solids (TDS)
Impurities from the feedwater will concentrate in the boiling water.
Conductive Heat Transfer
Electric Heating of Mass
Electric heating of an object or mass - temperature change vs. energy supplied.
Heat Transfer Coefficients in Heat Exchanger Surface Combinations
Heating Water by Injecting Steam
Water can be heated by injecting steam.
Online Saturated Steam Table Calculator
Online calculator to compute the thermodynamic properties of saturated steam.
Pipes and Cylinders - Conductive Heat Losses
Conductive heat losses through cylinder or pipe walls.
Power Plants - Performance Efficiencies
Power plants heat rates, thermal efficiencies, capacity factors, load factors, economic efficiencies, operational efficiencies and energy efficiencies.
Saturated Steam - Properties - Imperial Units
Saturated Steam - Properties for Pressure in Bar
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Steam & Condensate Equations
Steam consumption and condensate generation when heating liquid or gas flows
Steam - Enthalpy and Entropy Diagram
An enthalpy and entropy chart for steam
Steam - Flow vs. kW Rating
Calculate steam flow rate vs. kW rating.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Steam and Vapor Enthalpy
Vapor and steam enthalpy, specific enthalpy of saturated liquid, saturated vapor and superheated vapor.
Steam Entropy
Basic steam thermodynamics - entropy diagram.
Steam Heating Air
Superheated Steam - Enthalpy
Enthalpy of steam superheated to temperatures above it's boiling point.
Superheated Steam - Entropy
The entropy of steam superheated to temperatures above saturation points.
Vapor and Steam
An introduction to vapor and steam.
Water - Boiling Points at Higher Pressures
Water - Heat of Vaporization vs. Temperature
Water - Prandtl Number vs. Temperature and Pressure
Figures and tables with Prandtl Number of liquid and gaseous water at varying temperarure and pressure, SI and Imperial units.
Water - Saturation Pressure vs. Temperature
Water-Steam Mollier Diagram
Wet Steam - Enthalpy
Wet Steam - Quality vs. Dryness Fractions
Introduction and definition of steam quality and dryness fraction including calculating wet steam enthalpy and specific volume.
Wet Steam - Specific Volume
Wet steam and specific volume.
  • The Engineering ToolBox (2009). Thermodynamics. [online] Available at: https://www.engineeringtoolbox.com/steam-thermodynamics-t_12.html [Accessed Day Month Year].
