Rotating Bodies - Stress
Stress in rotating disc and ring bodies.
Stress in a Rotating Disc
Stress in a rotating disc can be calculated as
σ z = ω2r2ρ / 3
= v2ρ / 3
= ( 2 π n / 60)2r2ρ / 3 (1)
σ z = stress (Pa, N/m2)
ω = angular velocity (rad/s)
r = radius of disc (m)
ρ = density (kg/m3 )
π = 3.14...
n= revolutions per minute (rpm)
Stress in a Rotating Ring
Stress in rotating ring
Stress in a rotating ring can be calculated as
σ z = ω2ρ ( r12+ r1 r2+ r2 2 ) / 3                     (2)
r1 = outer radius of ring (m)
r2= inner radius of ring (m)
For a thin ring the equation can be simplified to
σ z = ω2ρ r                    (3)
r  = mean radius of ring (m)
Design Stress for materials used in Flywheels
Design Stress Flywheel Materials
MaterialDensity
(kg/m3 )
Typical Design Stress
( MPa)
Aluminum alloy 2700
Birch plywood 700 30
Composite carbon fiber - 40% epoxy 1550 750
E-glass fiber - 40% epoxy 1900 250
Kevlar fiber - 40% epoxy 1400 1000
Maraging steel 8000 900
Titanium Alloy 4500 650
"Super paper" 1100
S-glass fiber/epoxy 1900 350
  • Dynamics
  • The Engineering ToolBox (2011). Rotating Bodies - Stress. [online] Available at: https://www.engineeringtoolbox.com/stress-rotation-disc-ring-body-d_1752.html [Accessed Day Month Year].
