Lumber - Weights
Lumber dimensions  - inches vs. mm
The density and weight of lumber varies with the water or moisture content in the wood. Typical weights for green, kiln dried and pressure treated lumber boards are indicated in the tables below.
Note that nominal dimensions are not the same as actual lumber dimensions.
Green Lumber Boards
Green Lumber Boards - Weights
Weight (lb)
Nominal
Dimension
(in x in)
Length (ft)
18101216
2 x 4 1.7 13 17 20 27
4 x 4 3.6 29 36 43 58
4 x 6 5.4 43 54 65 86
4 x 8 7.2 58 72 86 115
4 x 10 9 72 90 108 144
4 x 12 10.8 86 108 130 173
6 x 6 8.1 65 81 97 130
Drying lumber takes time. Smaller and shorter boards use considerable less time than larger and longer boards. For larger pieces natural drying takes months and often even more than a year - depending on the surrounding temperature, moisture and air circulation. Smaller shorter pieces can dry in weeks.
Kiln Dried Lumber Boards
Kiln Dried Lumber Boards - Weights
Weight (lb)
Nominal
Dimension
(in x in)
Length (ft)
18101216
2 x 4 1.3 11 13 16 21
2 x 6 2 16 20 24 32
2 x 8 2.7 21 27 32 43
2 x 10 3.3 27 33 40 53
2 x 12 4 32 40 48 64
Weight of dry kilned lumber boards - imperial units
  • Right click the chart and open in new window for printing
Weight of dry kilned lumber boards - metric units
Example - Estimating Shipment Weight of Lumber
Shipment Lumber Weight - example
The shipment weight of 600 ft 2 x 4 dried lumber can be estimated from the chart to be approximately
800 lb
Pressure Treated Lumber Boards
Pressure treated with chemical preservatives.
Pressure Treated Lumber Boards - Weights
Weight (lb)
Nominal
Dimension
(in x in)
Length (ft)
18101216
2 x 4 2.1 17 21 26 34
2 x 6 3.2 26 32 38 51
2 x 8 4.4 35 44 53 70
2 x 10 5.5 44 55 66 88
2 x 12 6.6 53 66 79 106
4 x 4 4.8 38 48 58 77
4 x 6 7 56 70 84 112
4 x 8 9.3 75 93 112 149
4 x10 11.7 93 117 140 187
4 x 12 14 112 140 168 224
Weight of pressure treated lumber boards - imperial units
Weight of pressure treated lumber boards - metric units
  • The Engineering ToolBox (2013). Lumber - Weights. [online] Available at: https://www.engineeringtoolbox.com/green-kiln-dried-pressure-treated-lumber-weights-d_1860.html [Accessed Day Month Year].
